Hello everybody.
I found this site while I was looking for help for my Telefunken TV set with 618 chassis and I hope someone could help me.
When TV is turned on, it pumps 3 times and then goes off.
I did following: resoldier all cold joints
Changed all elcos in secondary part of power and line stage
Checked all diodes in secondary part of power and line stage with ohm-meter as well as most of transistors (marked as TL)
Exchanged line trafo
Asfter no success, I began to disconnect each secondary line to see which one is problematic. I found that:
- when RF17 (3R3) which goes through vertical deflection is removed
- or when BL55 connector is removed (vertical deflection coil)
- or when BG36 connector is removed (connection of vertical deflection to NS module)
TV turns on and works fine (except that picture is flat horizonztal line) and measuring on U5 is about 21 V.
While everything is connected and TV pumps 3 times, U5 voltage jumps up to 30 V while pumping.
If I disconnect any other secondary line or any other load of U5 while NS deflection is connected, TV will not turn on.
Can you help me as I ran out of ideas for repairing. Please, answer in english.
Thank you all in advance,
Ivo Andreis
