Universum FT8189 Servicemode
    Hersteller: Universum / Gorenje
    Modell: FT 4286
    Fehler: Servicemode
    Bereits durchgeführte Tests und Vorarbeiten:-- Hallo,
    muß bei diesem Gerät im 16:9 Modus die Verikalamplitude einstellen. Ich weiß zwar wie ich in den Servicemode komme, aber nicht wie ich die neuen Werte abspeichere. Hat jemand Unterlegen über den Gorenje Servicemode ? Chassis müßte ein S bzw. E9 sein.
    Mfg K.buß
  • Das sind zwei unterschiedliche Geräte die du hier angibst.
    Lennox
  • SWITCHING TO SERVICE MODE
    All other service settings of TV set are made in so called service mode of TV set operation. To enter this mode of operation press
    the keys in the following sequence: "TV", "I", and "STOP" in the period of 5 seconds from switching on the TV set to normal mode
    of operation. When the TV set is switched over to service mode the following status line with service parameter and parameter value
    appears on the screen:
    SERVICE PARAM: XX VALUE: xx
    The parameter to be set is selected with keys (P+/P-), and selected parameter is set with keys (volume+ /volume-). Each
    time you press the key for parameter selection ( ) the value of preselected parameter is stored.
    Therefore when the last setting is
    performed you must press one of the two keys once again. Values of individual parameters are expressed in hexadecimal form due
    to limited capacity of the memory. Values of individual parameters are variable from 0 to 3F, with the exception of parameters 11,
    12 and 13 where values are changed from 0 to 7F and O1, O2, O3, O4, which have value range between 0 and FF.
    When setting is finished it should obligatory be concluded with "STOP" key. After a few seconds the status line disappears and
    service adjustment is accomplished.
    NOTE: In case service adjustment is not ended in above specified mode (e.g. power supply breakdown), the
    adjustment should be repeated
