Habe hier einen englischen Text aus dem Sevice-Manual für Philips MC 50/22 vom 3-fach CD-wechsler.
Komme aber mit dem Text nicht klar.
Reassembling the tray
1. Insert carriage #1 above CD-drive.
Attention: The 3 cartridges are different (see picture 10).
2. Mount clamper (2x screw - see picture 5).
3. Connect mains. Set initializes - Clamper moves down.
4. Select CD 2 - Clamper moves up - Carriage #2 (not yet
inserted) will be moved above CD-drive - Carriage #1 moves
back - Clamper moves down.
5. While clamper moves down disconnect mains.
6. Open tray - using lever (block) as shown in picture 7.
Lift clamper - using lever (pin) as shown in picture 11.
7. Insert carriage #2 above CD-drive.
8. Lower clamper, close tray, connect mains.
Set initializes - carriage #1 moves above CD-drive -
Clamper moves down.
9. Select CD 3. - Clamper moves up - carriage #3 (not yet
inserted) will be moved above CD-drive - carriage #1 moves
back ® Clamper moves down.
10. While clamper moves down disconnect mains.
11. Open tray - using lever (block) as shown in picture 7.
12. Insert carriage #3 above CD-drive.
13. Lower clamper, close tray, connect mains.
Set initializes - Carriage #1 moves above CD-drive - Loader
unit reassembled successfully.
Danke im Voraus
Gruss Detlef
