Medion CTV2118 service mode
  • Is it really a Medion?
    I just know CTV2118 Roadstar or Telstar made by TCL china (chassis FS181CH--M17)
    In this case the servicemode is invoked this way:
    Press "display" on the remote and at the same time the Volume - on the frontpanel for about 7,8 sec.
  • I´m shure it is a chinese brand...either konka (as Gabrijel suggested) or TCL.
    Vedran, which type of remote...is it original?.
    Give the most important ics or a pic of the board to idéntify the chassis.
  • I agree that's china. The remote is original.
    Sound - Tda7057aq
    Vertical - tda8172
    main - VCT3831A
    The remote has 3 hidden buttons. One is Display ( again), second one is woofer on-off ( TV does not have it ), the third one is nothing ( or it is !?)
  • ok...now I´m rather sure its a TCL type ...somekind of Mxx chassis.
    another questions...
    do you have a "menu" knob on the remote ?
    which osd language do you have (some tcl servmode works only in english)
  • so please try (its from TCL M35)
    everything on the remote !!!
    english OSD (menu--> english)
    then press "menu" 4 times (menu system)
    then P- (timer menu)
    then Vol+ (timer sub)
    then Blue knob
    then ? knob
    if now the screen shows "Picture One" you´re right.
    with ? knob you can toggle to "picture two" etc. and change the settings...
  • I have found a chinese chassis with VCT3831.
    Factory menu
    1. Press MENU button to display the main menu, then press RECALL button five
    times continuously to enter factory mode. Press 0 button, then RECALL button
    to exit factory mode.
    2. After entering factory mode:
    Press 1 button to adjust Horizontal:including H-BLANK(HBS0、HBST),
    H-POSITION(HPOS),H-SIZE(H-P0)、H TRAPEZIUM(H-P1)、H PINCUSION(H-P2),
    H S-CORRECTION(H-P3)、H E-W CORNER CORRECTION(H-P4)。
    Press 2 button to adjust Vertical:including V PHASE(OFS)、HEIGHT(V-P1)、
    V SYMMETRY(V-P2)、V LINEARITY(V-P3),Angle、Bow adjustment are also Vertical
    adjustment.
    Angle adjustment: no upper adjustment, just switch the lower right and left
    to adjust.
    Bow adjustment: no upper adjustment, just switch the lower right and left
    to adjust.
    Press 3 button:Select some functions
    Press 4 button:Check DRIVE REF.
    Press 5 button:Enter into G2 mode.(This mode is for grid test)
    Press 6 button:Check CUTOFF.
    Press 7 button:Select some functions
    Press 8 button: Brightness/ Contrast/Color parameters setting.
    6
    Press 9 button:Memory data.
    3.Press PROG.△/PROG.▽ to select test item, and VOL+/- button to adjust the
    value, then press RECALL button to confirm and store
  • Thank you very much for your time but:
    first Menu : picture
    second : tune
    third : preset
    then goes out, also, do not have ? knob
    P.S. This answer is for Abdul....
  • its so difficult b´cause we dont know the Xakt TLC chassis and even subtypes like M35 and M35b have completelly different ways to invoke the servmode.
    do you have a "recall" knob ?
    edit: pardon... i meant...do you have a "reveal" and a "caps" knob
