How to enter service mode, please ?
Medion CTV2118 service mode
Is it really a Medion?
I just know CTV2118 Roadstar or Telstar made by TCL china (chassis FS181CH--M17)
In this case the servicemode is invoked this way:
Press "display" on the remote and at the same time the Volume - on the frontpanel for about 7,8 sec. -
It is Medion.
There is nothing written on the chassis, it has VCT3831A.
Can not open service mode by this way.
Thank you anyway. -
Try this:
Press MENU button of remote handset to display the menu,
then press RECALL button 5 times to enter factory service
menu. -
Thank you but it is not.
I´m shure it is a chinese brand...either konka (as Gabrijel suggested) or TCL.
Vedran, which type of remote...is it original?.
Give the most important ics or a pic of the board to idéntify the chassis. -
I agree that's china. The remote is original.
Sound - Tda7057aq
Vertical - tda8172
main - VCT3831AThe remote has 3 hidden buttons. One is Display ( again), second one is woofer on-off ( TV does not have it ), the third one is nothing ( or it is !?)
ok...now I´m rather sure its a TCL type ...somekind of Mxx chassis.
another questions...
do you have a "menu" knob on the remote ?
which osd language do you have (some tcl servmode works only in english) -
I have a "menu" knob.
OSD is Croatian, I changed it in english, nothing -
so please try (its from TCL M35)
everything on the remote !!!
english OSD (menu--> english)
then press "menu" 4 times (menu system)
then P- (timer menu)
then Vol+ (timer sub)
then Blue knob
then ? knobif now the screen shows "Picture One" you´re right.
with ? knob you can toggle to "picture two" etc. and change the settings... -
I have found a chinese chassis with VCT3831.
Factory menu
1. Press MENU button to display the main menu, then press RECALL button five
times continuously to enter factory mode. Press 0 button, then RECALL button
to exit factory mode.
2. After entering factory mode:
Press 1 button to adjust Horizontal:including H-BLANK(HBS0、HBST),
H-POSITION(HPOS),H-SIZE(H-P0)、H TRAPEZIUM(H-P1)、H PINCUSION(H-P2),
H S-CORRECTION(H-P3)、H E-W CORNER CORRECTION(H-P4)。
Press 2 button to adjust Vertical:including V PHASE(OFS)、HEIGHT(V-P1)、
V SYMMETRY(V-P2)、V LINEARITY(V-P3),Angle、Bow adjustment are also Vertical
adjustment.
Angle adjustment: no upper adjustment, just switch the lower right and left
to adjust.
Bow adjustment: no upper adjustment, just switch the lower right and left
to adjust.
Press 3 button:Select some functions
Press 4 button:Check DRIVE REF.
Press 5 button:Enter into G2 mode.(This mode is for grid test)
Press 6 button:Check CUTOFF.
Press 7 button:Select some functions
Press 8 button: Brightness/ Contrast/Color parameters setting.
6
Press 9 button:Memory data.
3.Press PROG.△/PROG.▽ to select test item, and VOL+/- button to adjust the
value, then press RECALL button to confirm and store -
Thank you very much for your time but:
first Menu : picture
second : tune
third : preset
then goes out, also, do not have ? knobP.S. This answer is for Abdul....
for Merckx,
Menu and recall 5 times does not works -
its so difficult b´cause we dont know the Xakt TLC chassis and even subtypes like M35 and M35b have completelly different ways to invoke the servmode.
do you have a "recall" knob ?
edit: pardon... i meant...do you have a "reveal" and a "caps" knob
yes
isses diese remote ?
