Wer kann helfen?
Wie gelangt man in den Sevicemode bei Sanyo CEP 2876D bzw 2576D?
Grüsse
Willi
Wer kann helfen?
Grüsse
Willi
Versuche das mal.....
Die Tasten MUTE, OK, TV nacheinander drücken.
MFG::::
hat leider nicht geklappt. Die Fb hat keine OK- Taste.
Gibt es noch andere Kombinationen?
Gruss
Willi
Unlocking the "Service Menu" and recommended settings.
1). Press and release memory key (diamond) on front panel. (Factory shows on screen).
2). Press Index/Menu key on remote control within 5 seconds.
The first tab on the service menu is highlighted allowing entry of the configuration code (02014) directly from the keypad. Pressing the remote menu key again changes the on screen display to the next tab heading "Geometry" with a list of features HO, SO, SI, AO, YO, etc with the top one HO being highlighted and vertical amplitude and a number written alongside. Operating either VOL+ or VOL- enable adjustment of the on screen number and the vertical size of the picture displayed. To alter the next parameter, press the sound button [under the volume + button] to highlight the next tab down. The recommended values are as follows;
CONFIGURATION NO. 02014 SETS SOUND INTERCARRIER/STANDARD ETC.
HO 02140
SO 01012
S1 00081
AO 00186
YO 00050
PO 15861
ZO 01369
P1 01665
Z1 00087
SP 00009
Danke Klaus !
Mit deiner Anleitung habe ich die Geometrie einstellen können.
Gruss
Willi
