Dreambox DM7000
loaded at: 00500000 00615170
relocated to: 00400000 00515170
board data at: 00513124 00513170
relocated to: 00405194 004051E0
zimage at: 004058D5 00512706
avail ram: 00516000 02000000
Linux/PPC load: console=null root=/dev/mtdblock5 rootfstype=squashfs ro console=
ttyS0,115200
Uncompressing Linux...done.
Now booting the kernel
Linux version 2.6.9 (tux@tux) (gcc version 3.4.4) #1 Sat Dec 12 15:10:35 CET 200
9
Built 1 zonelists
Kernel command line: console=null root=/dev/mtdblock5 rootfstype=squashfs ro con
sole=ttyS0,115200
PID hash table entries: 256 (order: 8, 4096 bytes)
Console: colour dummy device 80x25
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 29904k available (1900k kernel code, 520k data, 80k init, 0k highmem)
Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
NET: Registered protocol family 16
SCSI subsystem initialized
drivers/usb/core/usb.c: registered new driver usbfs
drivers/usb/core/usb.c: registered new driver hub
Squashfs 2.2-r2 (released 2005/09/08) (C) 2002-2005 Phillip Lougher
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
JFFS2 version 2.2. (C) 2001-2003 Red Hat, Inc.
Serial: 8250/16550 driver $Revision: 1.90 $ 7 ports, IRQ sharing disabled
ttyS0 at MMIO 0x0 (irq = 20) is a 16550A
ttyS1 at MMIO 0x0 (irq = 21) is a 16550A
ttyS2 at MMIO 0x0 (irq = 31) is a 16550A
loop: loaded (max 8 devices)
smc91x: IOADDR c305e300 doesn't match configuration (0).
smc91x: IO 0xc305e300: Unrecognized revision register 0x0000, Contact author.
smc91x: not found (-19).
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
IBM STB04xxx OCP IDE driver version 2.3
Using deadline io scheduler
dreambox: flash mapping: 800000 at 7f800000
DreamBOX rev3+: Found 1 x16 devices at 0x0 in 16-bit bank
Intel/Sharp Extended Query Table at 0x0031
Using buffer write method
cfi_cmdset_0001: Erase suspend on write enabled
disable flash VPP
Creating 7 MTD partitions on "DreamBOX rev3+":
0x00000000-0x00600000 : "DreamBOX cramfs+squashfs"
0x00600000-0x007c0000 : "DreamBOX jffs2"
0x007c0000-0x00800000 : "DreamBOX OpenBIOS"
0x00000000-0x007c0000 : "DreamBOX (w/o bootloader)"
0x00000000-0x00800000 : "DreamBOX (w/ bootloader)"
0x00120000-0x00600000 : "DreamBOX SquashedFS"
0x00000000-0x00120000 : "DreamBOX Cramfs"
drivers/usb/host/ohci-ocp.c: ohci_hcd (OCP) at 0xe0010000, irq 18
ocp_usb 07: new USB bus registered, assigned bus number 1
Hallo Leute,
Hab im moment Dreambox 7000 auf dem Tisch und folgendes Problem Netzwerchip LAN91C111 nicht erkannt wird und am LCD kommt auch nichts:)
Flashen per Nullmodem ist möglich
Das ist eine Dreambox 7000 Rev F 2002 mit STB04500 PBB 05C CPU
Habe aber CPU auf STB04500 PBC 05C umgelötet
Ist CPU STB04500 PBB 05C gleich STB04500 PBC 05C ???
Danke sehr
