Service Mode Panasonic TX-28LD8C
    Hersteller: Panasonic
    Modell: TX-28LD8C
    Fehler: Anfrage wegen Service Mode
    Wie gelangt man bei dem Panasonic FFS-Gerät TX-28LD8C Chassis
    Z8 in den Servicemode?
    Vielen Dank für die Bemühungen im voraus
    Ralf Schmerling
  • Hi Ralf,
    probier mal das (ist Service-Mode eines Z8T-Chassis):
    To access Service Mode select program position 99 and set sharpness to minimum.
    Press “MUTE” button on remote control and at the same time press the "V" button on the customer controls at the front of the TV, this will place the TV set into Service Mode.
    Press ' / ( buttons to step up / down through the functions.
    Press + / - buttons to alter the function values.
    Press “STR” button on the customer controls at the front of the TV after each adjustment has been made to store the required values.
    To exit Service Mode press “N” button.
    Gruß Ernst
