Sanyo CEP2876D - Servicemode ???
    Wer kann helfen?
    Wie gelangt man in den Sevicemode bei Sanyo CEP 2876D bzw 2576D?
    Grüsse
    Willi
    Z E I T löst jedes Problem!
    hat leider nicht geklappt. Die Fb hat keine OK- Taste.
    Gibt es noch andere Kombinationen?
    Gruss
    Willi
  • Unlocking the "Service Menu" and recommended settings.
    1). Press and release memory key (diamond) on front panel. (Factory shows on screen).
    2). Press Index/Menu key on remote control within 5 seconds.
    The first tab on the service menu is highlighted allowing entry of the configuration code (02014) directly from the keypad. Pressing the remote menu key again changes the on screen display to the next tab heading "Geometry" with a list of features HO, SO, SI, AO, YO, etc with the top one HO being highlighted and vertical amplitude and a number written alongside. Operating either VOL+ or VOL- enable adjustment of the on screen number and the vertical size of the picture displayed. To alter the next parameter, press the sound button [under the volume + button] to highlight the next tab down. The recommended values are as follows;
    CONFIGURATION NO. 02014 SETS SOUND INTERCARRIER/STANDARD ETC.
    HO 02140
    SO 01012
    S1 00081
    AO 00186
    YO 00050
    PO 15861
    ZO 01369
    P1 01665
    Z1 00087
    SP 00009
    Claudia hat 'nen Schäferhund
