Dreambox 7000 Defekt
  • Dreambox DM7000
    loaded at: 00500000 00615170
    relocated to: 00400000 00515170
    board data at: 00513124 00513170
    relocated to: 00405194 004051E0
    zimage at: 004058D5 00512706
    avail ram: 00516000 02000000
    Linux/PPC load: console=null root=/dev/mtdblock5 rootfstype=squashfs ro console=
    ttyS0,115200
    Uncompressing Linux...done.
    Now booting the kernel
    Linux version 2.6.9 (tux@tux) (gcc version 3.4.4) #1 Sat Dec 12 15:10:35 CET 200
    9
    Built 1 zonelists
    Kernel command line: console=null root=/dev/mtdblock5 rootfstype=squashfs ro con
    sole=ttyS0,115200
    PID hash table entries: 256 (order: 8, 4096 bytes)
    Console: colour dummy device 80x25
    Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
    Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
    Memory: 29904k available (1900k kernel code, 520k data, 80k init, 0k highmem)
    Mount-cache hash table entries: 512 (order: 0, 4096 bytes)
    NET: Registered protocol family 16
    SCSI subsystem initialized
    drivers/usb/core/usb.c: registered new driver usbfs
    drivers/usb/core/usb.c: registered new driver hub
    Squashfs 2.2-r2 (released 2005/09/08) (C) 2002-2005 Phillip Lougher
    devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
    devfs: boot_options: 0x1
    JFFS2 version 2.2. (C) 2001-2003 Red Hat, Inc.
    Serial: 8250/16550 driver $Revision: 1.90 $ 7 ports, IRQ sharing disabled
    ttyS0 at MMIO 0x0 (irq = 20) is a 16550A
    ttyS1 at MMIO 0x0 (irq = 21) is a 16550A
    ttyS2 at MMIO 0x0 (irq = 31) is a 16550A
    loop: loaded (max 8 devices)
    smc91x: IOADDR c305e300 doesn't match configuration (0).
    smc91x: IO 0xc305e300: Unrecognized revision register 0x0000, Contact author.
    smc91x: not found (-19).
    Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
    ide: Assuming 50MHz system bus speed for PIO modes; override with idebus=xx
    IBM STB04xxx OCP IDE driver version 2.3
    Using deadline io scheduler
    dreambox: flash mapping: 800000 at 7f800000
    DreamBOX rev3+: Found 1 x16 devices at 0x0 in 16-bit bank
    Intel/Sharp Extended Query Table at 0x0031
    Using buffer write method
    cfi_cmdset_0001: Erase suspend on write enabled
    disable flash VPP
    Creating 7 MTD partitions on "DreamBOX rev3+":
    0x00000000-0x00600000 : "DreamBOX cramfs+squashfs"
    0x00600000-0x007c0000 : "DreamBOX jffs2"
    0x007c0000-0x00800000 : "DreamBOX OpenBIOS"
    0x00000000-0x007c0000 : "DreamBOX (w/o bootloader)"
    0x00000000-0x00800000 : "DreamBOX (w/ bootloader)"
    0x00120000-0x00600000 : "DreamBOX SquashedFS"
    0x00000000-0x00120000 : "DreamBOX Cramfs"
    drivers/usb/host/ohci-ocp.c: ohci_hcd (OCP) at 0xe0010000, irq 18
    ocp_usb 07: new USB bus registered, assigned bus number 1
    Hallo Leute,
    Hab im moment Dreambox 7000 auf dem Tisch und folgendes Problem Netzwerchip LAN91C111 nicht erkannt wird und am LCD kommt auch nichts:)
    Flashen per Nullmodem ist möglich
    Das ist eine Dreambox 7000 Rev F 2002 mit STB04500 PBB 05C CPU
    Habe aber CPU auf STB04500 PBC 05C umgelötet
    Ist CPU STB04500 PBB 05C gleich STB04500 PBC 05C ???
    Danke sehr
  • Dreambox DM7000
    ttyS0,115200
    Uncompressing Linux...inflate returned FFFFFFFD
    exit
    Ich habe hier so eine Dreambox 7000 bekommen, ich tippe auf RAM IC202, IC203
    mal sehen
  • Dreambox 7000s rennt wieder:)
    Ich habe RAMs IC202, IC203 ersetzt, war aber glaube ich Müll im Flash, komplett gelöscht Flash und Image neu installiert.
    Und Dreambox 7000s läuft wie neu!
  • Noch eine Dreambox 7000, bootet nicht druch, auf LCD steht DREAM multimedia und als Bootlog kommt das da
    Ich tippe wieder auf IC202, IC203, werde sofort ersetzen.
    Dreambox DM7000
    ttyS0,115200
    9
    Built 1 zonelists
    sole=ttyS0,115200
    smc91x.c: v1.1, sep 22 2004 by Nicolas Pitre <nico@cam.org>
    eth0: SMC91C11xFD (rev 1) at 0xc305e300 IRQ 28 [nowait]
    eth0: Ethernet addr: 00:09:34:ge:loe:scht
    disable flash VPP
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 2 ports detected
    Initializing USB Mass Storage driver...
    drivers/usb/core/usb.c: registered new driver usb-storage
    USB Mass Storage support registered.
    mice: PS/2 mouse device common for all mice
    i2c /dev entries driver
    IBM IIC driver v2.1
    ibm-iic0: using standard (100 kHz) mode
    ibm-iic1: using standard (100 kHz) mode
    NET: Registered protocol family 2
    IP: routing cache hash table of 512 buckets, 4Kbytes
    TCP: Hash tables configured (established 2048 bind 4096)
    NET: Registered protocol family 17
    VFS: Mounted root (squashfs filesystem) readonly.
    Mounted devfs on /dev
    Freeing unused kernel memory: 80k init
    SQUASHFS error: lzma_fs returned unexpected result 0x1
    SQUASHFS error: Unable to read page, block 2b385, size 1f12
  • Gut ist es nicht, ich habe beide IC202 und IC203 ersetzt und das gleiches Bild.
    Mein Fehler, wenn man so etwas hat, bedeutet es, dass die daten die im Flash gespeichert sind, sind defekt:)
    Deswegen man soll Ram ersetzen 1 Stück dann neue flashen, dann laufen lassen
    Wenn alles Ok dann war dieses Ram, sonst wieder von vorne
    Ich habe jetzt neue geflasht und DM7000s lauft wie neu, muss aber beobachten, laufen laufen lassen:)
    Problem ich weiss jetzt nicht welche Ram IC202 oder IC203 wirklich defekt war:(((((
  • @tik-tak
    ich hatte auch so einen Fehler bei einer DM 7000 gehabt bei mir war es IC203 nach erneuern und neu flashen funktionierte die DM 7000 zu 100% habe dann aber IC202 zur Sicherheit auch erneuert
    heute habe ich wieder eine DM 7000 bekommen diese erkennt das wechseln der Smart Karte nicht im betrieb
    erst durch neustarten der DM wird die neue Karte erkannt
    ich hatte den Schalter im Card Reader unter verdacht war aber leider nicht so
    hast du einen Tipp für mich
  • Natürlich habe ich ein Tipp, CPU ersetzen sollte helfen:)
    Die Karten hängen am CPU direkt:))))
    Um es nachvollziehen, bitte CPU ablöten und messen
    Datasheet von der CPU ist nicht frei im Internet.
  • wenn es wirklich die CPU ist muß ich passen ;(
    da ich kein BGA Set besitze
    macht sowie so keinen Sinn wenn der Datasheet von der CPU ist nicht frei im Internet zu bekommen ist
    aber danke für deine Hilfe :thumbup:
    Einmal editiert, zuletzt von active9 ()
  • Noch eine Dreambox 7000, nach bestimmte Zeit vergisst die Gedächtniss
    Dreambox DM7000
    ttyS0,115200
    9
    Built 1 zonelists
    sole=ttyS0,115200
    eth0: Ethernet addr: 00:09:34:0f:5f:7e
    disable flash VPP
    IBM IIC driver v2.1
    SQUASHFS error: Unable to read page, block 187cae, size 5dfb
    IC203 MT 48LC8M16A2 wurde ausgelötet und HY57V1291620 eingelötet.
    WErde jetzt neue Flashen und laufen lassen, mal qucken ob ich getroffen habe:)
    Einmal editiert, zuletzt von tik-tak ()
  • So DM7000 hat 3 Tage gelaufen und an der 4 tag bootet nicht auf LCD steht Dreambox und im Bootlog kommt nur das da
    Dreambox DM7000
    Werde jetzt ein anderes RAM IC202 ersetzen, neu flashe und wieder laufen lassen
    IC202 ersetzt, hat aber nichts gebracht.
    Fazit:
    Wenn im Bootlog nur Dreambox 7000 erscheint und nichts mehr, ich werde Bootloader und Frontprozzesoor neue programmieren müssen.
    dann mal qucken
  • Hallo, zusammen,
    ich habe hier eine Dream 7000s mit einem bereits modifizierten Netzteil, die mehrere Fehler aufweist: die eingebaute 2,5Zoll-Festplatte läuft nicht hoch, das Bild zeigt große grüne Artefakte, der Ton hat Aussetzer und ein Sendersuchlauf bringt keine Verbesserung. Die Spannungen betragen 13.4 und 4,9 V. Es gibt keine sichtbar veränderten Elkos ode irgendwelche fühlbar heiße oder verbrannten Bauteile. HAt jemand einen Tip für mich, ob es ein Netzteilfehler sein kann oder eher der Prozessor den Geist aufgibt?
    Danke für Eure Hilfe. :)
  • Falls keiner mit Lotkolben oder Messspitze rumspielt, geht CPU nicht defekt!
    Sie sollen alle andere Spannungen auch messen
    Bei dm7000 gehen ab und zu RAMs Bausteine defekt
    Da hilft eine nach dem anderen austauschen
    Aber erst alles abklemmen, neue sauber flashen und qucken!
    Eventuell Bootlog erstellen und hier anhängen
  • Dreambox 7000s und Problem Bootet nicht und im Display steht "ERROR UC0"
    Alle Spannungen usw sind Ok. Als Bootlog kommt das da, ein Ausschnit des Bootloges.
    clear mem...done.
    fp: attaching fp at 0xee to adapter IBM IIC
    FPrev 0.06
    fp selftest: PASSED.
    using a0900000 as framebuffer base
    VID_DISP_MODE set to 0088e6c0
    registered framebuffer
    allocated major 250 for denc.
    [DENC] set PAL
    [DENC] disable WSS
    demux set source
    core: Loaded IBM STB04xxx core driver
    write 1 event's ...
    [MPEG] setting vertical disp border to 288 lines (vsize is 0)
    [MPEG] setting horizontal disp border to 360 lines (hsize is 0)
    audio init
    AUDIO_CLEAR_BUFFER
    demux: init
    [XP0] 2048kb ram used for queues
    xp0_clk_stop
    i2c_master_send failed.
    stb04_pig: $Id: stb04_pig.c,v 1.16 2007/06/12 19:28:18 ghost Exp $
    lcd.o: LCD driver (KS0713) module
    avs: attaching avs at 0x94 to adapter IBM IIC
    [AVS] set mode to FBAS
    write 1 event's ...
    drivers/usb/core/usb.c: registered new driver hid
    drivers/usb/input/hid-core.c: v2.0:USB HID core driver
    Das Problem ist der Tuner! Nach dem Austausch rennt die Box. Hier ist der Bootlog, wieder Ausschnitt
    FPrev 0.06
    [DENC] set PAL
    [DENC] disable WSS
    demux set source
    write 1 event's ...
    audio init
    AUDIO_CLEAR_BUFFER
    demux: init
    xp0_clk_stop
    registering frontend...
    disable continuous tone
    already got a frontend.
    detected tuner.
    write 1 event's ...
    booting from flash
    found key = /eli[AVS] set mode to RGB
    tedvb/video/colo[AVS] set mode to FBAS
    rformat
    returning 2
    setting co[AVS] FBLK:1
    lor format 2
    VIDEO_SELECT_SOURCE
    open video clip-mode
    VIDEO_CLEAR_BUFFER
    VIDEO_PLAY / VIDEO_CONTINUE, state 1 0
    write 1 event's ...
    [MPEG] setting vertical disp border to 0 lines (vsize is 576)
    [MPEG] setting horizontal disp border to 0 lines (hsize is 720)
    VIDEO_STOP, state 0
    cp: /var_init/tuxbox/config/enigma/enigma.conf: No such file or directory
    mount: Mounting /dev/scsi/host0/bus0/target0/lun0/disc on /var/mnt/usb failed: N
    mount: Mounting /dev/scsi/host0/bus0/target0/lun0/part1 on /var/mnt/usb failed:
    mount: Mounting /dev/ide/host0/bus0/target0/lun0/part1 on /var/mnt/hdd failed: N
    hdparm: /dev/ide/host0/bus0/target0/lun0/disc: No such file or directory
    [enigmanet] ifconfig eth0 192.168.0.6 up netmask 255.255.255.0
    eth0: link down
    [enigmanet] route add default gw 127.0.0.1
    Start done.
    stopping Core
    rm: cannot remove `/var/etc/.dont_restart_enigma': No such file or directory
    [MOVIEPLAYER] Version 2.1 starting...
    enigma, Copyright (C) dbox-Project
    enigma comes with ABSOLUTELY NO WARRANTY
    This is free software, and you are welcome
    to redistribute it under certain conditions.
    It is licensed under the GNU General Public License,
    Version 2
    Was sehr interessant ist, diese Tuner wird in eine Dreambox 5620 gesteckt und die Box funktioniert und die Sender werden auch hell!!!
    Das heisst, die Kommunikation zwischen CPU und Tuner bei den beiden Boxen ist unterschiedlich!!!
    Ich werde IC SL1935C ersetzen, som dass auch im DM7000s der Tuner funktioniert:)
  • SL1935C ersetzt und der Tuner wird von Dreambox 7000s erkannt:)
    Also falls bei Dreambox 7000s die Fehlermeldung am LCD "Error UC0" steht ist diese IC SL1935C im Tuner defekt!
    Und Dreambox 5620 zum testen Tuner TDQF-S001F nicht geeignet ist! Denn der ist nicht so geschaltet wie bei DM7000S!
    Tuner mit defekter IC SL1935C läuft in einer DM5620 ohne Prübleme und wird auch erkantt!!! Das wusste ich nicht bis jetzt:)
    AUDIO_CLEAR_BUFFER
    demux: init
    xp0_clk_stop
    detected tuner.
